NO HIGH BEAMS..Help ..PLEASE
Old Aug 14, 2005 | 05:27 PM
11 Second Club
Default NO HIGH BEAMS..Help ..PLEASE
HI
I have a 01 Yukon.
Last night I went to high beans and they didnt come on.But the foglights stay on and the high beam indicator in the gauge cluster doesnt light up either.
Do I have a bad dimmer switch.relay etc..where should I start to look for the problem..
any help or suggestions would be helpful..thanks
Old Aug 14, 2005 | 06:41 PM
Start with the headlights, relay, then your headlight switch on the dash and finally your dimmer switch on the column
Old Aug 14, 2005 | 07:01 PM
check the under hood fuse for the hi beams, could be loose or bad
Old Aug 14, 2005 | 07:57 PM
11 Second Club
ok thanks...headlights R ok..so R the fuses..and so R the relays..I will check dimmer switch next
thanks again
madmann26
Apr 29, 2020 09:17 AM
smok'nZ
Oct 6, 2015 01:14 PM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 06:27 AM
