Next Mod. Help
Like said above you return the tranny pressures to stock... Also you zero out the desired shift times to turn of adaptive shift learning... Adaptive shift learning measures how fast the shift is occuring can compares it to the desired shift time table.. If the shift is too fast it will lower the tranny pressure and vice versa, this helps the tranny last longer in stock form, so basically it compensates for worn parts... With a shift kit the tranny will shift alot faster than stock, so if the desired shift times are not zeroed out it will keep lowering the trannys line pressure....
I'm not trying to avoid a tune, reason for the questions is...Say you have a shift kit, vette servo, torque converter and cam installed. It is said you "should break in" mainly the tc and cam for a couple hundred miles before you put your truck on the dyno and tune it. The issue being the untuned break in period of the vehicle.
Thanks, now how does this complicate things if say a 3000 tc stall was added to an untuned truck on top of the shift kit and servo?
i am pretty sure it includes fluids,filter, and gasket but i will find out for sure.
bodyguard6799
Dec 13, 2004 12:39 AM
