New track times! And some fun on the way home.
Old Sep 18, 2005 | 11:25 AM
bluecajun5.3's Avatar
11 Second Truck Club
nice times man. got that big Z running strong. next time try opening up the exaust to give you some more top end. it helped me alot and i didn't lose, but gained on the bottom end also. congrats...
Old Sep 18, 2005 | 11:51 AM
thunder550's Avatar
High on diesel fumes
It looks like you were running a little lean there too, O2 readings in the LOW 800's. Timing is 6, I wonder what you IAT correction table is set at, just curious that seems like a lot of timing being pulled. Better safe then sorry I quess. 132 Cool man, I never thought of using HP for that I might have to keep that in mind. I would like to know how fast mine will go.
I have sent a couple log files to Nelson for updates, but put it on hold pending the arrival of my meth kit. Once that is in I am going to be getting some more updates and getting everything dialed in just right, so there may be a little bit of power left to be had from the tune.
What have you done to open up the exhaust? I am pretty much running a long open pipe, cats are gone and the Corsa muffler is straight through. Did you unbolt the cat back or y-pipe?
Old Sep 18, 2005 | 05:08 PM
im running pacesetter lt's with the off road y pipe with no cats. i still have the factory catback and tailpipe with a hooker aerochamber muffler in place of the factory one. all i did was unbolt it at the end of the y-pipe flange. so i ran it open y-pipe if you'd wanna call it that, lol.
Old Sep 19, 2005 | 09:40 AM
thunder550's Avatar
I might think about pulling the y-pipe and getting a couple of short extensions off the header collectors to keep the o2 sensors happy....hmmmm.....
Old Sep 27, 2005 | 12:11 AM
zippy's Avatar
figured i'd post it for the f**k of it.
i thought the iat's were lower, but i forgot i'd just made a pass with it.
Old Sep 27, 2005 | 09:11 AM
thunder550's Avatar
Just had to go and one-up me eh?
Old Sep 27, 2005 | 09:43 AM
zippy's Avatar
i just found it again last night and thought i'd post it. slight timing difference though...
Old Sep 27, 2005 | 10:29 AM
Yellowsierra's Avatar
Yeah your 02's need to read low 900's. My truck was running low 800's like yours and I bought hptuners to fix my lean problem and man did that make a difference. I went from running low 13's with my whipple to running mid 12's at 10psi.
Old Sep 27, 2005 | 11:06 AM
thunder550's Avatar
I'm still in the process of getting some tune updates from Nelson...put it on hold temporarily until I get my alky system installed.
Old Sep 27, 2005 | 11:22 AM
onyx's Avatar
14 Second Truck Club
im on your *** thunder. nice run!
