need help! underbody rust
Old Aug 21, 2004 | 10:20 PM
Default need help! underbody rust
well apparently the guy who owned the truck before me loved to go off roading, as a result the factory undercoating wore off and there's a lot of rust on the crossmember and frame. i'm planning on powerwashing the remaining caked mud. should i get a wirebrush bit and a drill and try to sand off the rust myself, then apply por-15? or can i just use sand paper and if i can what grit. what's the best underbody coating i can put on it? lastly if i take it to a body shop how much should it run me? thanks
Old Aug 22, 2004 | 11:39 AM
04BlackSilverado's Avatar
This stuff says its better than POR-15 hands down!
Check It Out
Old Aug 22, 2004 | 12:11 PM
jimmyblue's Avatar
Knotted wire wheel on a cheap Chinese angle grinder
would make pretty short work of things. Wear good
goggles and a thick shirt or you'll look and feel like
you lost a fight with a porcupine. The real tight bits
you might still need the toothbrush and hand effort.
I wouldn't bother with sandpaper. You'll use a lot of
it and it is not good at concave or corrugated surfaces.
Plus, you don't need to get to bright metal if you are
using POR-15, it actually wants some native oxide.
Don't know about this other stuff, looks worth checking
out. POR-15 needs two coats (the POR primer has no
UV resistance). If the Chassis Saver works like POR
but is also UV stable then that's a bonus.
Old Aug 22, 2004 | 12:32 PM
marc_w's Avatar
My like, 10 month old truck has rust on various underbody pieces.
I've got a few rattle cans of flat black Rusoleum here to see if they take care of it.
Old Aug 22, 2004 | 05:03 PM
Flyer's Avatar
I *think* there is a longer period of warranty for rust on these trucks than the standard 36k/3 year. That might be worth checking out.
Old Aug 22, 2004 | 07:04 PM
chevymec's Avatar
The warranty on rust is in or under the paint if im correct.. If you take it to a shop they will prob. just spray it with an undercoating spray
Old Aug 23, 2004 | 03:06 PM
the rust warranty - has to be through the panel
dsbodley
Nov 14, 2015 09:46 PM
carid
Oct 28, 2015 08:24 AM
trxmxzx
Sep 29, 2015 07:42 AM
Tim94gt
23
Sep 18, 2015 04:51 PM
Closer_2001
Sep 16, 2015 11:46 AM
