need help!!! hard time pumping gas into truck
i have 04 Chevy silverado 1500 with 5.3. the problem has been getting worse now it wont let pump gas it stop like ever 2 dollars. when i open my gas cap before fueling up it sounds like alot of air is coming out or sucking in. the truck isnt throwing any codes either.
Sounds like a plug beather line on the fuel tank. Check your warranty. It should be covered under emissions/pollution control which have a much longer warranty then bumper to bumper.
If not check the small line that runs beside the larger fill hose.
My votes on the tank vent solenoid.
Edit: Found an old post that should help. Sounds like 04BlackSilverado was having the same problem.
https://www.performancetrucks.net/fo...d.php?t=368161
