Need Help Fast !!!
Alright I went to the desert yesterday, I went on a bump and suddenly everything went reset the clock and the doors unlocked and locked it selves. and from that time everytime I exit a turn and want to spin the tyres little it does the same thing. like the electrecity in the car switches off and on again even the SCT dash scan resets. So I want to know whats the problem Im afraid the airbags will go BOOM on me.
You've got a bad connection somewhere. Probably a ground. Check all the wires under the hood and make sure they aren't loose. Check the battery cables to make sure thay are tight. Just my thoughts.
Is this problem happening on the 08? I think I remember reading about a similar problem on an 07-08 truck that turned out to be an open circuit in one of the junction blocks. Isn't the truck under warranty?
Yea...but I don't see how that should affect the electrical system, if what I mentioned is the problem. There might even be a TSB about it if you do some hunting...
murderedSS
27
Oct 12, 2015 11:13 AM
whitelazer
Sep 22, 2015 09:38 PM
