Need help!
My truck kept showing the codes for bad knock sensors and had a rough idle so i pulled the intake and replaced them and the intake manifold gaskets put it all back done this tons of times on mulitple trucks and now it wont idle for longer then 30 seconds and shuts off like it is dumping way to much fuel and it will have a random ping noise and so i pulled it back apart and the rear knock sensor didnt go down all the way tight the center of the knock sensor just spins in its outer shell and the exhaust dumps black smoke any idea what could be causeing all this ?
thanks
thanks
theres none i dont think its stayin runnin long enough to throw one. The truck doesnt wanna start right away either like the timing is being set retarted and it did none of this till i put the new knock sensors in im gunna replace the messed up new one tomorrow and hopefully that will fix it
Black smoke generally means an injector is running wide open. I'd say go injector by injector and see if unplugging one makes a difference. Did you miss any connectors when you put the intake back on, or tear a wire in the harness where it comes behind the alternator?
