need help
Old Jan 27, 2009 | 05:17 PM
02gmcbandit's Avatar
Default need help
need help, whats the best way to take the clutch fan off?
Old Jan 27, 2009 | 05:20 PM
00ChevyScott's Avatar
Wearin' da big hat
PB Blaster/Deep Creep + Pipe wrench + a mallet + about 15-20 good whacks
Old Jan 27, 2009 | 05:21 PM
dirt track racer 81's Avatar
i used to take a small bolt and stick it in one of the small holes and then stick a big screw driver between the bolt and the big nut and then use a big crescent to take it off
Old Jan 27, 2009 | 05:22 PM
or if you got an old belt try wrapping it around somethin like this but on the water pump pulley instead of the crank pulley
Old Jan 27, 2009 | 05:33 PM
thanks guys , i jus got it off, took about 5 good wacks with the dead blow
Old Jan 27, 2009 | 05:35 PM
Wearin' da big hat
awesome!
Old Jan 27, 2009 | 07:34 PM
do anyone know anything about procomp fans? we hooked up a 16 inch to my buddy's truck, but im not sure if its pushing on pulling?????? its mounted to the radiator on the inside but it feels like the air is going towards the motor not the radiator???
