Need help
Old Jun 13, 2008 | 06:24 PM
03rado5.3ls's Avatar
Default Need help
This morning on the way to work I had my cruise set at 50 and all of a sudden my gauge cluster dings and says reduce engine power, so I pull over in the median and try to take off again there was absolutely no power in the truck but it never cut off. So I was able to creep to a gas station and turn the truck off for about 10 mins later I cranked it up and drove on to work. Does anyone know why this happened I know that I have a bad rear o2 sensor could that be it or is the computer going out I have a westers tune. Thanks
Old Jun 18, 2008 | 07:51 AM
Silver-Dollar's Avatar
PMing you a source.
Old Jun 18, 2008 | 08:24 AM
SiniSter5.3's Avatar
I had that happen to me the only difference is mine caught on fire , 06 sierra 5.3
Old Jun 18, 2008 | 08:44 AM
tried to post pics but will not let me say they are to big and don't know how to make them smaller
Old Jun 18, 2008 | 12:36 PM
well it happened again today along the same stretch of road and the cruise was set so I cut the truck off and let it set cranked it back up and no prob
Old Jun 18, 2008 | 06:35 PM
454SuperSport's Avatar
I ran into this same thing with a 03' sierra. ended up replacing the throttle body. try cleaning it first, could be some carbon buildup causing the blade to stick.
Old Jun 21, 2008 | 05:40 PM
thanks but ,my truck is throwing a code po430 Catalyst System Efficiency Below Threshold (Bank 2)
Old Jun 21, 2008 | 07:38 PM
terravast4's Avatar
sounds like a bad cat on passenger side
Old Jun 22, 2008 | 01:45 PM
I'm thinking about replacing the stock cats with after market cats from magnaflow are they worth the money or not need suggestions
Old Jun 22, 2008 | 04:19 PM
ChevyTruck's Avatar
something else
i have them on my silverado and made a sound and difference. thay are only about 75 bucks. i would get them if i was you.
