Muffler F**K up
Old Feb 1, 2004 | 01:35 PM
gonzo 6.2's Avatar
Default Muffler F**K up
Welp,I made the wrong choice,just had a magnaflo 5x8 24" duel 3" in single 3" out.******* LOAD,sounds like short glass packs dumped with no cats.So I have no doubt this one wont stay on.I should have gone with my first gut instinct which was the bigger 5x11x22,I guess it has much more drone control.Man i hate wasting money.I dont want to add aids to it,plus there is no room since it's dual 3"pipe going in.
Old Feb 5, 2004 | 09:36 AM
oxidizr's Avatar
Moderator / Sponsor
Default Im sorry you feel that way but you got exactly what you wanted.
Gonzo:
-----Original Message-----
Sent: Friday, January 23, 2004 11:00 AM
To: rwaitas@magnaflow.com
Subject: Re:
I sent you 2 emails this was the first i think. Here is a copy of the second one.
I didnt think you would mind responding to a magnaflow question.I have used several magnaflows in the past and I am looking to do something again.I will copy and past my sig from the Ls1 tech board.
2K 1/2 ton xcab 4x4 GMC 6.0 swap stage 1 6.0 heads .020 off,comp 212/218 522/529 114Lc longtubes,HD cats,HD exhaust grafted in,UPD,Ed Wright
I have dual 3" going in,what muffler are you using on the hummer? or the escalade?
Of these magnaflow PN do you have a recommendation?
12763
12762
12599
12398
12590
I am after flow and not noise or drone. Please advise.Thanks Gonzo 6.0
**** If I read this correctly you weer looking for "FLOW AND NOT NOISE OR DRONE"
I made my recommendation based upon your criteria of flow
this was my response:
12398 3" / dual 3" (internal perforated X) 5x8x24
12763 3" / dual 2.5" 7x7x24
12762 3" / dual 2.5" 7x7x30
12590 3" / dual 3" 5x11x22
12599 dual 3" / dual 3" (internal perforated X) 5x11x22
From what I can tell it seems you are going to be working with a 330-350 RWHP combo.
Are you looking to do dual in / single out, true duals or whatever works best?
I would stick with a dual 3" inlet muffler with at least a single 4" or dual 3" outlet for best flow. A dual 2.5" will flow the cfm however if noise is not an issue the 3"s will give you room to grow. I prefer the 5x8x24 with perforated internal x because it saves mass and space. I also prefer the sound/tone of this muffler with 6.0L and larger applications. The 5x11x22's are more for resonance control, but are much more bulky.
Richard Waitas
Engineering / Product Development Manager
MAGNAFLOW Performance Exhaust / CAR SOUND Exhaust Systems
Main: 1-800-990-0905 x 3309 Direct: 949-858-8121 Fax: 949-459-0452
23201 Antonio Parkway Rancho Santa Margarita, CA 92688
I believe I gave you the information to make your own decision and I really hope you were not bashing my recommendations based upon your decision.
Old Feb 5, 2004 | 12:48 PM
gonzo 6.2's Avatar
Like it says,i am after flow not drone or noise.Look,I take full responsibility for the decision,my gut told me to go with the largest case possible,and i should have known better since all magnaflow catback systems with 6.0 or 8.1s use the largest case.This muffler i have would be fine on a GEN2 truck but the GEN 3 motors just have a resonence they devlope all to themselves.The engineer at corsa even said to go with the largest magnaflow since he doesnt offer seperate mufflers.OXI.Anyone asking you for a recommendation is putting you in a bad spot i know,everyone has a differnet idea of what sounds loud or drones or has enough tone.Maybe i looked at you response all wrong,i thought you were recommending the smaller cased muffler over the larger.although i dont think the bigger magna flow will flow less CFM than the one i had installed
'02SOMz28
Nov 2, 2015 05:47 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Rockrz
Sep 29, 2015 09:07 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
