misfire problems
Old Jun 22, 2010 | 08:47 PM
gregs323's Avatar
Default misfire problems
Hey guys i know i'm very new, but i've been browsing for the last few years anf now i need some advise. here is a link to another thread i've started if you want to see it from the beginning..
http://forum.efilive.com/showthread....sfire-problems
the lowdown is that i'm having a misfire code p0300 (random misfire) when i'm driving with throttle position 50% or greater it flashes the light at me. i have almost no power and i can barely reach 4000 rpm. through scanning i find cylinder 4 and 6 to be the culprits
so far i have new plugs, wires, fuel filter, switched coil packs around and replaced my intake gasket. still the same misfire on 4 and 6.
i just did a compression test and came up with
#2-165 PSI
#4-150 PSI
#6-155 PSI
#8-170 PSI
#1-170 PSI
#3-165 PSI
#5-175 PSI
#7-130 PSI <--i rechecked this one a few times and it really is 130 psi
tomorrow i'm going to switch around the fuel injectors to see if the problems follows..i'm really running out of things to check anyone have any input? Thanks!
Old Jun 25, 2010 | 05:41 AM
shandy294's Avatar
I read your EFI link;the left bank cat was the problem?
Old Jun 25, 2010 | 03:52 PM
budhayes3's Avatar
PT's Slowest Truck
I was about to mention, usually when you have random multiple misfires and the engine won't rev above 4k a cat is clogged...
Old Jun 28, 2010 | 09:43 AM
shandy294's Avatar
Thanks;how do you like your new transmission?
Old Jun 28, 2010 | 11:38 AM
budhayes3's Avatar
PT's Slowest Truck
I love the trans, still getting used to how hard the lockup in the converter is...if I had a new belt on there that wasn't squealing every time it goes into lockup I'm sure that I'd like it more...just moved so I haven't really had any time or money to mess with it, plus, Justin is still ironing out a few things with the tune, and I'd like to rework the exhaust as soon as some spare scratch becomes available...thanks for asking
Old Jun 30, 2010 | 08:03 AM
shandy294's Avatar
Sounds good.
madmann26
Apr 29, 2020 09:17 AM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
