Message Center fake out
I've put up a couple threads about my conversion from vacuum assist brakes to hydroboost. My truck also came equipped with the vacuum assist pump that I've removed. Now every time I start up the truck I'm getting a "Service Brake Booster" in the message center. No big deal, just cancel the message and gone till the next startup.
I've done a little research and have come up with the wiring diagram. Anybody care to tell me how I could wire the plug I've got disconnected to cancel the message? I'm a laymen with electrical circuits but I think If I were to send either a ground or some volatge to the signal wire to the message center it would stop it?
I am sure this won't help you but I will give it to you anyway,
Us Denali guys with the air ride shocks will get a service air ride when we switch out the factory shocks, There are no aftermarket shocks for us. We put a resister on all 4 shock connectors and that keeps the codes from popping up.
Mark
Mark
Mark
Mark
I haven't done mine yet, shocks are sitting on a bench in my garage, I can't seem to find the thread that explains it, but I do remember that they just tried a bunch of different resistors until one worked.
Sorry I couldn't be of more help,
Mark
Mark
Think I got it. Read the troubleshooting flowchart for the circuit and they keep checking everything for short to voltage for the message to display.
Took a chance and just jumpered the signal wire to ground. Here is the schematic drawn. Message gone. Don't know if anything else will pop up.
Picture of the connector. Black wire to Dark Blue wire jumped. Works so far. Taped it up and tucked it back somewhere hidden.
Sounds like it worked, but to be on the safe side, I would check resistance between pins A and F of the Supplemental Brake Assist Pump Motor and jump the pins of the connector with a similar resistor.
