Master or Slave Cylinder
Old Feb 18, 2017 | 12:57 PM
Archaic2021's Avatar
Registered User
Default Master or Slave Cylinder
So on my 91 chevy 5-speed I have lost clutch pressure.
Driving home the other night the clutch would not let me change gears. I had to pump it several several time to get pressure back. Once I did it drove fine.
I just put a new starter on so I was thinking I didn't get all the air back out of the Slave Cylinder so I started to bleed it again. For the next hour all I got was bubbly fluid. Same thing keeps re-occuring it will loose all pressure then I can pump it up and get it back but literally after a minute all the pressure goes back out until I pump it up again.
No fluid leaks of any kind that I can see. Does this sound like a bad slave or master cylinder for the clutch?
Old Feb 19, 2017 | 08:26 AM
MikeGyver's Avatar
My opinion is master cylinder. I think it might be the seal on the pushrod side of the piston sucking air on the upstroke.
Old Feb 20, 2017 | 08:36 AM
Registered User
I believe you are right. A friend of mine has a new slave cylinder laying around. I installed that and bled it out and it seemed that was it. Truck drove perfect. Let it sit overnight and now the same thing is happening. Althought now at least it doesn't take as long for the clutch to get pressure back.
Gonna go buy and grab a master cylinder on my way to work and slap it on. I'm just happy it's nothing internal all easy fixes lol
