LS1 w/nv4500 trans help!
Old Dec 28, 2014 | 04:02 PM
chvy=power's Avatar
Default LS1 w/nv4500 trans help!
Swapping a ls1 into my 95 c2500. I'm re using the original nv4500 transmission. The ls1 has a flywheel and clutch off a 2001 6.0. When I mount the trans up the throw out bearing isn't even close to engaging the pressure plate....I'm lost. Do I need a flywheel spacer?
Old Dec 28, 2014 | 04:46 PM
brewster240's Avatar
you sure its a 2001 6.0?
the 99-00 6.0 and early 4.8 manual trans engines have a longer crank
Old Dec 28, 2014 | 06:11 PM
chvy=power's Avatar
Yea I ordered a flywheel for a 2001 6.0 from advance auto. Now whether it's the right one or not, idk. It is an 1 1/2" from back of block to surface of flywheel. Is this right?
Old Feb 14, 2015 | 06:52 PM
gonzo 6.2's Avatar
what crank do you have ? early long flange or short normal LS1 flange? they are almost flush w/seal
Old Feb 14, 2015 | 07:33 PM
George C....'s Avatar
Formerly ScreamingL
old school trannys need to have flywheel spaced
Old Feb 14, 2015 | 07:35 PM
gonzo 6.2's Avatar
Depending on the crank
Old Feb 14, 2015 | 09:02 PM
Formerly ScreamingL
yes but that only applies to the early 6.0s and some 4.8s
Old Feb 16, 2015 | 05:19 AM
chvy=power's Avatar
It has the short flange. I got it figured out a while back. Had to go with an adjustable throw out bearing, ram 1550 flywheel, and a ram clutch
flatblack83
Jan 3, 2026 07:10 PM
nrmskate
Aug 11, 2015 02:44 PM
RONIN LSX
Aug 11, 2015 12:03 AM
Black-Syde
Jul 6, 2015 02:12 PM
