06 stepside
rebuilt 6.0 with 706 heads (replacing 5.3)
HG compression.054, SCR 10.5 approximately
BTR stage 2 truck cam, beehives already on heads
50 lb injectors
Circle D 3000-3200 stall
uprade to 3.73 gears with a locker
up in the air about long tube headers
no towing, weekend cruiser/shop truck. Am I on the right track. The higher compression concerns me with stock lower end. Got a good local tuner with dyno to set it up right.
I agree, but a .051 put me close to 10.8. Piston up .005. Haven’t put it together yet, just doing all the pre-assembly measurements and math.
I hear ya. Think of it like this. Yes, it would increase your compression a few tenths, but at the same time, it reduces the tendency to knock. Worst case, if you had pull back a degree or two of timing, the engine is going to be more efficient and make more power with good quench anyway.
Measure all your pistons above deck, take the highest, and then pick a HG that gets you between .036" and .043". Then tune accordingly.
Yes, I would love to get quench to around .040, but that would require a .045 HG and bumps SCR to almost 10.8. Not sure about that much compression and the quality of pump gas today.
