Knock Sensor????????????
Old Aug 10, 2009 | 09:29 AM
charcold-bowtie's Avatar
The front one.
Old Aug 10, 2009 | 09:30 AM
Aquinosteven's Avatar
Thanks
Old Aug 10, 2009 | 11:27 AM
budhayes3's Avatar
PT's Slowest Truck
As mentioned, since you're going to have it all apart, I'd replace them both as well as the sub-harness. Might want to consider replacing the intake gaskets since you'll be breaking that seal open. I'm sure that most guys will say that they're re-usable, but it seems like I've read more than one thread where guys were experiencing lean issues and vacuum leaks after removing the intake...
Old Aug 10, 2009 | 11:29 AM
^^^ yeah i asked the guy at napa and he said the seal should be like new but i have 130,000 miles on my motor and im sure its far from new haha. I thinks im just gonna have my local shop do it. I dont wanna break anything haha
Old Aug 11, 2009 | 02:23 PM
krambo's Avatar
Yes, possible corrosion on in the knock sensor connectors. You'll need some RTV too...it's common for water to get under the intake into the valley cover where the knock sensors are located. GM's fix is to build a "dam" of RTV around where the knock sensor connectors plug in to keep water from getting in there. If you search for "knock sensor" you should find pics of the RTV fix that I'm referring to. The sub-harness to the knock sensors may need to be replaced also if it's oxidized to the point of no return.
Agree!
Originally Posted by Aquinosteven
Last question, the code was for bank 1 so which of the two sensors is bank 1. I would think its the first one?
As mentioned above, it is the front one however do both while you are in there. You have alot of mile on the original ones anyway.
Knock sensor and where to squeeze the connector to get it off:
Closer look at the plug and the knock sensor:
Installed new one, just screw in...careful not to overtorque!
And when you are done installing the new ones, seal it up with some RTV:
Old Aug 11, 2009 | 10:18 PM
Thanks for the write up. I got the truck back today and they said that the sensor was fine and that it was just a bad batch of fuel which is a load of BS. I filled up today with 93 and ill see if the light comes back on.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
trevorh1
Sep 27, 2015 08:47 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
