ive got issues
Old Oct 17, 2007 | 05:25 PM
Default ive got issues
what can i clean my map sensor with? brake cleaner or carb?
my truck is idleing sometimes 1500rpm, 2000, sometimes 750.. its getting annoying trying to talk over my exhaust at the drive thru.
codes p0107 map or boro pressure signal low
p0131 p0151 02 signal low bank 1 and 2 sensor 1
p0300 random cylinder misfire
p0463 fuel lever sensor circuit signal high/open--- i assume this one is why my gas guage doesnt work often..
i cleared them and the only one back so far is the p0107. anyone know what could cause this? i just put in a 02 pcm and havnt got the crank position relearn yet but i dont see that as the problem and to top it off i need my inspection done this month too
Old Oct 17, 2007 | 05:56 PM
guess this should be under tuning\diognostics. sorry wasnt thinkin
Old Oct 17, 2007 | 06:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The MAF (mass air sensor) or the MAP? If you mean maf then you can use a spray elctrical cleaner or a product like CRC's mass airflow sensor cleaner...
CRC Mass Air Flow Sensor Cleaner is the safe and effective alternative to "underground" methods of MAF sensor cleaning. Don't us aggressive chemicals like brake parts cleaners or carburetor cleaners on MAF sensors. These can cause serious damage to sensitive parts. Use CRC MAF Sensor Cleaner -- It's the right product for the job! It safely and easily cleans the MAF hotwires and electrical components without damage to the wires or plastic housing. Cleaning is simple, safe and fast. The whole job should take less than 10 minutes!
Mass Air Flow Sensor Cleaner benefits and features:
Safely cleans and protects MAF Sensors.
Plastic-safe and leaves no residue.
Increases horsepower.
Decreases hesitation and pinging.
Improves fuel economy and MPG.
Reduces rough idle.
Use every time you clean or change your air filter
Old Oct 17, 2007 | 06:35 PM
no its the map sensor.. i dont see what would cause the signal to be low and i dont want to buy another and that not even be the problem
Old Oct 17, 2007 | 06:38 PM
CHEVRACER83's Avatar
You Cant Clean Them As They Are A Pressure Sensor.... I Would Guess It Is Probably Bad. But When It Comes Down To It Your Probably Just Gonna Have To Bite The Bullet And Replace It.... You Can Probably Get One For A Decent Price
Old Oct 17, 2007 | 08:53 PM
adam1803's Avatar
I've got one sitting right here, $20 shipped if you want it. shoot me a PM
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
