intake swap question
Old Feb 23, 2016 | 07:41 PM
chevyman68's Avatar
Registered User
Default intake swap question
so im swaping a 2010 intake w injectors,92 mm throttle boby delete egr to my 2000 silverado 5.3L will it start and run to dyno shop or is mail order tune needed prior to swap inf feed back please what have you other guys done
Old Feb 24, 2016 | 05:44 AM
06 4.8's Avatar
As long as you have all the right fuel system changes and the x link for the tb, it should be fine.
Old Feb 24, 2016 | 06:20 AM
madmann26's Avatar
I thought the 2010's were rectangle ports? :/
Old Feb 24, 2016 | 11:16 AM
MrHorsepowerLSx's Avatar
11 Second Club
It is a cathedral port as long as the motor it came from was a 5.3..... You cannot put a rectangle port head on a small bore motor as the valves will strike the deck surface.
Old Feb 24, 2016 | 11:58 AM
Wolftrk99's Avatar
Only 6.0/6.2 are rectangular port requires a 4" or larger bore to accomodate the huge valves they have
Old Feb 24, 2016 | 01:01 PM
chevyman68's Avatar
Registered User
its a 5.3L from vortex max motor cathedral port im concerned w it running after wo tune right away people said it wont run wo tune ?
Old Feb 24, 2016 | 02:07 PM
Wolftrk99's Avatar
It will idle and put around but wot will suck until you get the tune mostly due to the injectors being higher pressure and different parameters are needed
Old Feb 24, 2016 | 07:42 PM
11 Second Club
I can't remember if unused the injectors from a TBSS when I did the swap. But you can swap intakes and use you injectors And it will run fine, then use the bigger injectors when you are going to get it tuned
Old Feb 24, 2016 | 08:27 PM
Wolftrk99's Avatar
I used the injectors that were on my intake and wot sucked but idled fine and low rpm driving was ok.... Idle speed was bigger issue
Old Feb 29, 2016 | 01:54 PM
Justhereforinfo's Avatar
Hey Chevyman, once you get it all buttoned up, would you mind posting up your opinion on weather this swap was worth the time, money, and effort.
Thanks
