intake bolt torque sequence?
ive got my 02 tahoe tore down so i can replace my knock sensors. i am wondering if ther is a torque sequence when tighting the bolts ex( start in the middle and work my way to each end alternating sides) or what ? next is what coolant would you guys run? is ther such a thing as a relearn for the knock sensors? any thoughts would be great thanks..
thanks guys. my parts should be comming this afternoon hope to have her back up and running tomorro nite with any luck.. just a thought a person may want to add the pic of the bolt sequence to the 6.0torque spec thread..
thanks again guys
thanks again guys
The correct way (per GM) is 2 passes, with a sequence similar or equivalent to the drawing above. I can't remember the torque specs or sequence off hand, but if you work on your vehicle a lot it's worth it to subscribe to ALLDATA, it has all this info. Also, you will need an inch-pound torque wrench to properly torque everything,
Intake Manifold Bolt
First Pass in Sequence 5 Nm (44 inch lbs.)
Final Pass in Sequence 10 Nm (89 inch lbs.)
Intake Manifold Sight Shield Bolt (RPO LQ9 - 6.0L Engine) 9 Nm (80 inch lbs.)
Intake Manifold Sight Shield Bolt (4.8L, 5.3L, and RPO LQ4) 10 Nm (89 inch lbs.)
Intake Manifold Sight Shield Retainer Bolt 5 Nm (44 inch lbs.)
I personally tighten to 120in/lbs because I've encountered seal issues on machined heads.
torque wrench isnt a prob for me most of the newer tractors i work on require inch lb torque setting for something on them..
