Ign lock bad, need help
Old Jan 9, 2008 | 12:07 AM
bigbob's Avatar
Default Ign lock bad, need help
I have a 2001 silverado with a bad ignition lock cylinder. The only manual I have is the trusty Haynes. In there it says to insert the key and turn it to the "start" position so it can be removed. The problem is that it won't turn from the "OFF" position. So now what do I do? I haven't started any disassembly yet. If you guy know something that can help please let me know. All help is very appreciated. Thanks in advance.
Old Jan 9, 2008 | 07:29 AM
Dock Rocker's Avatar
I had a lock smith change mine. It was only about 30 bucks or so.
Old Jan 9, 2008 | 09:25 AM
bigbob's Avatar
Thanks Dock, that was one idea I hadn't thought of. I'll check into it. btw, that's a great avatar pic.
Anyone else have any knowledge on this?
Old Jan 9, 2008 | 07:47 PM
bgray's Avatar
TOTM: June 2007
K take the plastic steering wheel column **** off. Turn your key to the on position, then notice on top of the ingition cylidner housing there is a TINY whole, stick a pick screw driver in there and the cylidner will slide out....done....repalce with new keyed cylinder.
If you need to turn it off, sticka scrtew driver in and turn it off...
Old Jan 9, 2008 | 08:03 PM
Truckshop's Avatar
the lock cylinder is messed up. it will not turn
Old Jan 10, 2008 | 01:20 AM
bigbob's Avatar
Thanks for the responses. I ended up getting the cylinder to turn.
I spoke to a guy that works at a local Chevy dealer. He's run into this before and told me to get some liquid graphite. He said there's something about the graphite that loosens things. Anyway, I shot some of it into the cylinder and then put in the key.Still stuck. Then I used a SMALL lightweight mallet and tapped the back of the key a few times, stopping to try the key after two or three taps at a time. after about the 3rd set of taps, PRESTO, it turned! Now all I have to do is follow the replacement procedure that bgray mentioned, and I'll have it. Thanks alot guys. Even though I got the info locally, these responses let me know I wasn't in it alone. Thanks again.
Bob
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
Cammed4ever
Sep 30, 2015 03:38 PM
Chevy305
Sep 28, 2015 09:21 PM
