Idle shake
Old Nov 20, 2005 | 02:50 PM
BlackLM7's Avatar
I wouldn't worry about it. If there was a miss, stumble, etc. you would have a check engine light on the dash. Did you do the crank relearn after installing the Westers PCM? If you think it's a problem, have the dealership check it.
Old Nov 20, 2005 | 06:40 PM
MikeGyver's Avatar
Mine's always done it.
Old Nov 22, 2005 | 09:30 PM
rednecknate's Avatar
Default shakey
mine only started the shake after the 4l80e swap, my trnny guy said its in the convertor and not to worry so far so good 10k on swap,only does it 550-1050ish rpm then wreeeeeeeeeee RADIX GOES ZOOM ZOOM hehe radix best mod to my truck so far i hate the frikin power loss of the 80e 6.0 stroker here we come .
Old Nov 22, 2005 | 09:48 PM
stone150's Avatar
mine too, my f150 did it really bad
Old Oct 29, 2006 | 08:11 PM
My 03 1500 hd has 135k on it now and has done it for as long as i have had the truck, about 20k, It really gets on my nerves but i am about to do some work on it and get it tuned so i hope it can tune out of the truck. I would be really interested to figure out what causes it though
Old Oct 29, 2006 | 08:14 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Man this is an oldy (4 me). Factory sets idle too low. A good tune will eliminate most of it.....Unless you put a big 'ol nasty cam in there
Old Oct 29, 2006 | 09:58 PM
allenmehrer's Avatar
yea i had to same problem. as for my truck... a couple bottles of fuel injector cleaner later... the problem was gone, and its stayed gone for about 10k miles and counting. i think i had an injector getting dirty and the problem only showed at idle.
Old Oct 29, 2006 | 11:18 PM
i ran a big bottle of the lucas fuel treatment through my truck over about month and a half using about 5 ozs. per fill up instead of the 3 that they say use. No help still did it.
Old Oct 30, 2006 | 12:26 AM
TouchOfEvil04's Avatar
Mine does it....but only started since i did the cam/motor swap.My 5.3 would every now and then start kinda chop idleing.All stock motor but it would almost idle like it had a big ol cam.It would do it for like a second or two then stop and it only did it every so often.Not sure why it ever did that.
Old Oct 30, 2006 | 07:35 AM
dirt track racer 81's Avatar
both my motors had the severe case of the shakes..
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
BlownHD
Oct 3, 2015 12:24 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Pimpinpete
Sep 8, 2015 07:39 PM
