i want to drop the truck 3/5 or 4/6
1 Attachment(s)
will my wheels allow me to keep the same size tires on them with a 4/6. i have the rear lowered 3inches right now in this pic with the front stock and it sits level
Attachment 145830 |
What size tires do you have? 275/45-20? 285/50-20? You might be OK with the 275 tires but you will probably rub in the front if you have 285 tires. The backspacing on the wheels will make a difference too. We need specs on your tires and wheels.:judge:
tires are a 275/45/20 and i have looked a few places about the wheels and can only find it saying a offset of 14 so i dont really know what that means
The offset and backspacing relate to an extent, but we will also need the width of the wheel.
the wheel is a 20 x 8.5 with a 275/45/20 and a offset of 14 (whatever that means). ive heard that i will need a 275/40/20 tire or maybe a 255/45/20 i really want to go with a 4/6 drop
yes sir you will need a 40 series tire!! If you go with a 4/6 drop. We learned the hard way at heat way. The sidewall of the 45's went to hell.
Originally Posted by BBLS1
(Post 3762877)
I'd say go with a 255/45/20 I run a nitto 255/55/18 and it's a great street tire to go with my 5/7. |
245/40/20 IMO. The wheels you have have a slightly smaller backspace than the ones I have and mine are real close to rubbing over bumps on the back(they don't though). You can roll your fender lips though and then could probably run the 255/45/20 suggested above.
or you could go with a 255/40 up front and a 275/40 out back. either size^^ you go with you shouldn't have any trouble.
i just want as big a tire as i can get without rubbing
