I have a leak problem!
Old Jan 17, 2004 | 02:09 PM
RChevy4.8's Avatar
Default I have a leak problem!
Ok, I have had this problem for about a year. Thought I had it fixed, but I noticed it again the other day. I was vacuuming my truck and noticed some dampness under the carpet. I thought it may have been from the condensation tube, but I have unclogged that. Yesterday we had a lot of rain, and my passenger side was soaked, pulled up the carpet and there was a huge puddle. I think there is a leak somewhere. What could this be?
Old Jan 17, 2004 | 02:16 PM
What year is your truck? Where did you see the dampness, front or back? I had a '99 GMC that went through 4 back windows before it finally sealed properly. If it leaks that bad, you should be able to get inside and let someone spray it down really good with a nozzle and you should be able to see the leak. If you think it might be the back window, it is probably happening in the seams of the outer seal.
Old Jan 17, 2004 | 02:34 PM
RChevy4.8's Avatar
I have a 2001 regular cab, it's not coming from the back. somewhere in the front, not sure if it is from the firewall, or the door seals.
Old Jan 17, 2004 | 02:41 PM
In that case, I would say door seals. Should be easy to find.
Old Jan 17, 2004 | 03:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
Just for ***** and giggles, I would check the heater core too.
Old Jan 17, 2004 | 03:14 PM
RChevy4.8's Avatar
Yeah, I have had people tell me that. But, doesn't the heater core leak coolant? 'cause I am leaking water.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
