Hydroboost issues.......
Old Apr 27, 2014 | 11:17 AM
DrX's Avatar
DrX
Default Hydroboost issues.......
My 04 has factory Hydroboost brake assist. Applying the brakes just sitting in Park causes a drop in engine RPM or a stall. The greater the pressure on the pedal, the greater the RPM drop. This does not seem to be affected by tuning. Has anyone seen this before?
Old Apr 27, 2014 | 12:24 PM
Atomic's Avatar
I have a gauge for that
Sounds like a problem with the power steering pump...
Old Apr 27, 2014 | 12:47 PM
TSA's Avatar
TSA
My hydro-boost braking is also dropping the engine RPM...Ditto on the power-steering pump...it's ready to sh*t the bed.
Old Apr 27, 2014 | 03:28 PM
DrX's Avatar
DrX
Could be, but it is not making any noises. Out of all the threads I could find via Google for various makes and models with similar issues, it is never stated how the problem was resolved. i.e. Was it the pump, or the hydroboost unit?
Old Apr 27, 2014 | 11:06 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Have you every flushed the power steering fluid???
Old Apr 28, 2014 | 08:15 AM
DrX's Avatar
DrX
No. Pump(original) has about 45,000 miles on it.
Old Apr 29, 2014 | 11:23 PM
1FastBrick's Avatar
Try flushing the power steering fluid.
Just like brake fluid, It breaks down over time as well as collects dirt, moisture and can start to plug up the feed side of the system.
Old May 2, 2014 | 01:22 PM
DrX's Avatar
DrX
Haven't serviced anything yet. Just did a little testing...
I notice an RPM drop just spinning the steering wheel in P/N, more if I crank it all the way, but no stall as I can cause by pushing hard on the brake.
I set the P/N and In Gear Desired airflow tables and the Desired Idle Speeds for both to exactly the same values. If I step on the brake in Gear, there is a very slight RPM drop but it does not stall, whereas in P/N it will stall unless I apply the brake very gradually.
TXSZ66AVLANCHE
Dec 17, 2015 11:45 AM
YenkoST
Dec 2, 2015 11:36 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
1320Chicken
Jul 14, 2015 10:58 PM
mrgrim
Jul 8, 2015 08:12 AM
