How are you guys priming the oil system in your new motors?
Old Jun 11, 2008 | 11:18 PM
hirdlej's Avatar
Default How are you guys priming the oil system in your new motors?
So, how're you guys doing it? Please don't tell me to install engine without plugs and rotate it over. That answer is unacceptable. What combinations of fittings and pumps are you using to tap into an oil galley and prelube the engine?
Old Jun 11, 2008 | 11:43 PM
BlownChevy's Avatar
blownerator
25 Year Member
I filled the oil filter, filled the oil pan and fired it up. Done it this way for years, never had an issue.
Old Jun 11, 2008 | 11:53 PM
hirdlej's Avatar
What about the fact that this motor is essentially bone dry on the inside? It's a LQ4 that's been sitting for 4 years without running. Can I fill the engine up with 12 quarts until the crank and rods are submursed in oil? I am not going to break loose the con rod bolts or main caps.
Old Jun 12, 2008 | 12:25 AM
chevyguy7802's Avatar
+1 Ive never had a issue either.......
Old Jun 12, 2008 | 12:46 AM
Banned
+2 just fill her up
Old Jun 12, 2008 | 12:55 AM
2005 Silverado's Avatar
SPAM HUNTER
the only would really be to just make it so it couldn't get fuel or spark then crank it for a while, IMO that would be the only "safe" way.
Dustin
Old Jun 12, 2008 | 03:53 AM
viciousknid's Avatar
Where's the Beef?
It only takes a second for oil to launch thru the engine. If your worried about it just take the valve covers off and pour some oil over the lifters.
I've seen 9 second cars fill em up and crank em over without problems.
Old Jun 12, 2008 | 09:53 AM
hirdlej's Avatar
I don't like these recommendations, Even without the spark plugs in (compression) and fuel being added, I don't like the idea of dry bearings on the crankshaft. What does GM do when the engines are new or a service tech replaces a motor? I thought I read somewhere there's a GM oil priming tool for the ls1 engines?
Old Jun 12, 2008 | 10:56 AM
ZZebes's Avatar
Moregrip had a pump he used, heres what you can do, get an A/N Oil adapter plate, figure out what fittings you need to get to a fluid pump like a hand sprayer, attach to the pressure side and start pumping to your hearsts delight till you get all the oil in there you want
Old Jun 12, 2008 | 05:44 PM
Truckshop's Avatar
Plugs Out And Injectors And Coils Disconnected. Spin It Over With The Starter Till Oil Comes Out Of All Of The Pushrods. Never Had A Problem.
