how not to take header bolts out
Old Mar 12, 2012 | 10:40 PM
anti seize the new ones
Old Mar 13, 2012 | 12:37 PM
Ketis's Avatar
i soaked them in PB for a day, then i used my 3/8 impact.
they all came out of my 03 with 150k miles in illinois... saltxxx
Old Mar 13, 2012 | 12:41 PM
TXsilverado's Avatar
i've never had a problem. just put a wrench on it and twist! atleast that's what i do. mine has been apart a dozen times though. still reusing the factory bolts from 2001 lol.
Old Mar 13, 2012 | 01:16 PM
Mangled03gmc's Avatar
Baltimore Whore
Start the truck up for a few min, to get some heat in the heads. Then take a long extension or punch, punch the tops of the bolts using a hammer, to shock them. Then take your time, try to bust the bolts loose. IMO you should have used oem bolts back in there.
Old Mar 13, 2012 | 05:41 PM
40series's Avatar
Default got it done
got it done today worked nice i took the wheel well out and discovered a header leak i didn't even have to pull the whole exhaust . i simply unbolted the left header and turned it out a bit , enough to get my Aluminum gasket in. i used anti seize on the ARP's clicked in my 22 ft lbs and put it all back
the engine should run a bit better w/o the leak
Old Mar 13, 2012 | 09:54 PM
SnakeOiler's Avatar
So you got all of your broken bolts out?
Old Mar 14, 2012 | 12:18 AM
texasglock23's Avatar
Originally Posted by 40series
these bolts only have been in for 2 yrs , am i being overly cautious?
Originally Posted by greasemykey
you can never be to cautious when avoiding broken bolts. i broke the one right next to the firewall. the only way to get it out is to remove the head. makes for a bad day.
It just happens, the very next weekend we did a set with almost 100k more miles, none broke! I just have **** poor luck.
Old Mar 14, 2012 | 07:54 AM
LS1DIME's Avatar
The one next too the firewall is tough, but my 2004 5.3L truck had the rear most bolt broke when I got it, we simply unbolted the rest of the manifold, breaking two other bolts in the process, took a pair of needle nose vise grips and held a nut centered up with the hole ( mine was broke below flush with the manifold surface ) fill the hole and nut with a nice steady weld and allow it to cool, they backed right out! The weld does not hurt the head unless you just get stupid with it, this even worked on the back driver side bolt!
Old Mar 14, 2012 | 09:54 AM
40series's Avatar
Default did passenger side yesterday doing drivers today
did passenger side yesterday doing drivers today, i got really nice angles when took the wheel well out, pb blaster and go slow i just let the big wrench do the work and feel it -the drivers side have been out recently so im not scurd
zblee
63
Jun 10, 2023 01:25 PM
chopperloco
Jul 10, 2016 10:45 PM
slowlsx
Aug 10, 2015 05:33 PM
mr03silverado
Jul 26, 2015 01:05 PM
