How much hp
Old Mar 24, 2008 | 08:43 AM
Hole$hot's Avatar
Default How much hp
What is a 2004 6.0 in a 2500HD Silverado rated at stock, and with a Magna chargr on it
Thanks,
Chris
Old Mar 24, 2008 | 12:25 PM
Zick's Avatar
Stock is 300HP
Add the Magna and it's a lot more
Not sure but I'm gonna guess about ~100 more HP.
Old Mar 24, 2008 | 12:33 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
380rwhp...imo
Old Mar 24, 2008 | 01:22 PM
Hole$hot's Avatar
Default L92
Ok, thanks guys.
One more question. If I have a Magna Charger on it with a stock motor, can I use the L92 heads as well. Would it be worth it to change over?
Thanks
Old Mar 24, 2008 | 01:24 PM
Hole$hot's Avatar
Default 380hp
Originally Posted by Low_LQ4
380hp...imo
Is that with the Magna Charger?
Old Mar 24, 2008 | 03:38 PM
PSM's Avatar
PSM
I believe he is refering to rear wheel horse power. Most numbers thrown around here are at the wheel since its much easier to measure on a chasis dyno than pull the motor out.
The stock Lq4 6.0 in your truck is engine rated at 300hp and 360 ft lbs
Old Mar 24, 2008 | 08:31 PM
Low_LSX's Avatar
Yes with the stock radix pullie and stock motor it should put you some where around that.
