how are jimmys/blazers?
Old Sep 17, 2006 | 08:59 AM
DriveATransAm's Avatar
i was looking at jeeps. they are freakin expensive though.
you mean the 4.0 I6, right.
Old Sep 17, 2006 | 08:11 PM
COLDZ71's Avatar
Yep, my bad. I bought my 98 Cherokee back in 02 for 6000. Does seem kinda high.
Old Sep 18, 2006 | 11:26 AM
SaintLos's Avatar
Mid 90's Blazers/Jimmys have pretty sorry brakes. The later years are better, but you're still better off all around with a well kept high mileage Cherokee with the straight 6. They are like cockroaches...in the good sense.
Old Dec 15, 2006 | 02:50 AM
BLK85's Avatar
12 Second Club
Originally Posted by 03NHSilvy
the powertrain is pretty stout. The things to look for are the intake manifold gasket likes to leak sometimes, as do the oil cooler lines (the filter is remote mounted). The biggest issue on these trucks in the front end, you'll want to check the balljoints, wheel bearings, and steering linkage CAREFULLY, as failures in these components is common. I had a 98 Jimmy, leather and the whole 9 yards. Pretty comfrotable truck, I had to replace most of what I mentioned above, but it was still a decent truck. 98+ have 4 wheels discs, which I'd try to get . All have pushbutton 4x4, and there are some issues there as well, with the vacuum actuater on the axle and the encoder (shift) motor right on the transfer case being the most common problem areas.
What kind of miles do all these problems happen? Im looking at a 2000 Blazer with 52k. Is there anything I can count on going wrong in the next say 10k miles? How do I check the ball joints, wheel bearings, and steering linage like you say are big issues?
Old Dec 15, 2006 | 07:43 AM
To check the steering/ball joints, jack up the front of the vehicle...put your hands on the wheel at 3 and 9 o'clock postions and try to wiggle the wheel. If there is alot of movement, then the tie rod ends are probably bad. Now place your hands at 6 and 12 and try to wiggle the wheel...if there is alot of movement then the BJs are probably on their way out. The wheel bearings you can usually tell on a test drive...they sound like a loud humming noise inside that changes pitch when you turn the wheel at speed.
I doubt you'd have any signs of probs. at 52K, but w/ S-10s, anythings possible. I owned a '99 4WD p'up and a 5" lifted '98 ZR2 p'up and they had their fair share of problems, just like '03 NHSilvy said. The '98 was better than the '99, but it still lost 4WD, the intake leaked, plus a ton of nickel and dime stuff. I'd stay away from the S-10s and go w/ the 4.0 XJ Cherokees, even if they are more $$. You'll be ahead at the end w/ less repair bills. My DD/winter beater '94 Jeep Grand Cherokee w/ the 5.2 V8 and 170K is practically bulletproof.
Old Dec 15, 2006 | 12:10 PM
negativeswitches's Avatar
step 1 replace your automatic shift on the fly 4wd with a manual lever
i seen a kit on trucks a couple years back... or was it one of the shadetree mechanic shows
Old Dec 15, 2006 | 01:19 PM
Yeah, it's called the PosiLok, it replaces the actuator in the front axle. You still have to push the button on the dash to get the t-case engaged, but then you pull the cable to engage the front axle.
