How high can i rev my 5.3 L33 aluminum block?
Old Jan 2, 2011 | 02:54 PM
05gmcsierra's Avatar
Default How high can i rev my 5.3 L33 aluminum block?
hey guys well just had a quick question.. i was reving my engine too 6200 on my 212/218 cam but since i decided to upgrade to a 217/223 on my 5.3 i was thinking im probably going to rev a bit higher.. no matter what happens i will only push it to prob 200 rpm higher then what ever Hp i make max at the dyno. but just had a quick question i had heard something about the aluminum blocks not being able to rev past a certain rpm.. can i get some input on that? thanks..
Old Jan 2, 2011 | 03:51 PM
viciousknid's Avatar
Where's the Beef?
A quick search will show that plenty of people are shifting in the mid 6k range. I shift at 6400 with my Iron 5.3 with 216/220.
That should be plenty for your cam as well.
Old Jan 2, 2011 | 03:56 PM
Yea I c where people r shifting and that's where I would like to shift mine at but heard that the aluminum blocks can't rev too high.. I was trying to c how high is that Max point.. Ive seen iron blocks rev to 7 k but no aluminum blocks..
Old Jan 2, 2011 | 04:22 PM
Where's the Beef?
Looking on LS1 Tech (since they are almost all Aluminum block) I see that a STOCK LS3 has a redline @ 6600rpm. I don't see why your Cammed L33 can't shift at 6400.
As far as I know the Aluminum Blocks have longer cylinder sleeves than Iron blocks do which should allow them to spin higher with more reliability. Someone PLEASE chime in on this.
Old Jan 2, 2011 | 04:26 PM
Where's the Beef?
Read just now some guys on there running 150 shot, trapping low low 11's and shifting at 6500rpm.
Old Jan 2, 2011 | 04:45 PM
Well yea I've heard ppl doing around 6500 Max... not like ill b doing more just wanted to get an idea.. ill keep looking for more info myself.. thanks..
Old Jan 2, 2011 | 07:18 PM
Anyone else have any info?
Old Jan 2, 2011 | 07:22 PM
anheuserbusch08's Avatar
6600 seems like a great shift point with that size cam.
Old Jan 2, 2011 | 07:29 PM
Rhino79's Avatar
9 Second Club
Id say about 8000.............................................j k!
Actually Id shoot for 8-10% past your peak hp on the dyno
Old Jan 2, 2011 | 07:47 PM
00ChevyScott's Avatar
Wearin' da big hat
Been shifting my iron 5.3 at 6800 for a long time now, and I've seen Corey shift his as 4.8 at ~7000+ a few times at the track.
