help! window died!!
12 Second Club
help! window died!!
hey guys my window wont roll down or do anything.
i put my ear to the door and it sounds like the relay is clicking and when i pull the switch up or push it down the interior lights dim a little so i dont think its the switch so im thinking its the motor.
truck is a 04 escalade ext and its the front passenger window.
anyone got any ideas?
thanks guys.
thanks guys.
more than likely its the motor, chevys always have a huge issue with the front pass motor going out. all mine have. you can take it off and use wires at the connection to see if the motor turns. also a issue MAY be that the window is frozen to the rubber seal? mine was the other morning, i about went crazy cause i got in and neither window would go down and finally decided to check the seal and sure enough it was frozen not leting the window roll down
slocaddy
09-25-2015 12:42 PM
Closer_2001
09-24-2015 09:15 PM
nic351
09-24-2015 09:43 AM
