HELP no start after motor swap....
After swapping the new motor in, trying to crank and getting nothing, we've double checked the cam/ crank sensors, checking the wiring harness, we don't have spark at all.... I don't have a clue as to why... Any help?
Man we have checked everything and then again, and went and ate a pop-tart and come back and checked! Its a pita for sure! Could it have anything to do with security? What would fix an issue like that?
Thanks guys!
Thanks guys!
does the truck turn over at all, if so it happen to me too, did you switch out computers, i did a 6.0 swap from my 4.8 and the 6.0 computer had a secruity lock on it. i put the 4.8 up and the truck ran, not right but ran...took it to a friend and had it dyno he fixed the computer and ran like a champ
Turns over, no spark...
Same PCM, the busted 5.3 that I pulled ran the same day as the motor swap.... The 5.7 should crank and idle on the 5.3 tune... Were leaning towards it being something wrong with or a bad crank sensor all together. I'm going to swap them tomorrow.
