HELP HELP HELP
Old Nov 4, 2002 | 06:17 PM
paul4's Avatar
Default HELP HELP HELP
I took my stock radio out to attach SNI to hook up an amp. I hooked the box up to the rear speakers. however i had to cut a few of the wires to figure out wich ones were the rear. i put all of the stuff back together EXCACTLEY how it came off and now my dash lights (for at night) will not come on unless i put the dimmer switch all the way up (wich turns all the interior lights on) and also my fog lights do not work now. Any ideas sugestions or anything?????
-Paul
Old Nov 4, 2002 | 06:21 PM
Default Re: HELP HELP HELP
Sounds like you didn't put them back how they were.I would definatly take it to a pro! <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Nov 4, 2002 | 06:44 PM
paul4's Avatar
Well the wires are color coated so i know that they can not be wrong and not to sound like a smart *** but it does not take a rocket scientist to wire somthing like a radio. I am thinking that mabey it is just coincidence and that my dimmer switch is messed up. any more suggestions???
Old Nov 4, 2002 | 06:57 PM
I didn't take you as being a smart ***...I know plenty of people that barely know where to put the gas in.I don't know how mechanically inclined you are. There is a dimmer wire that runs to the radio you didn't mix it up did you?
Old Nov 5, 2002 | 03:46 PM
red53gmc's Avatar
Check all your fuses and recheck the connections.
Old Nov 5, 2002 | 09:46 PM
Brandon Boomhauer's Avatar
could there be more than one of the same color wire you might have got crossed?
Check everything again, and the connections of the wires etc...
