Help!!!
Hey all, I have a 00 GMC RCSB, and I had to take the dash out recently to replace the clutch pedal. Well, I finally got it put back together but the Airbag light is coming on in the cluster. I'm pretty sure that I reconnected all the airbag connections, and will double check this afternoon. But if thats not the problem, is there a reset for the airbags? Is there something that the dealer needs to do with a computer? Thanks guys!
definately check to see if on the back side of your ait bag you have to safety taps fully seated will definately thow the light othe than that check all connections. if you cannot find it your gm dealer can pull a air bag code and can diagnose your problem. hope that helps
