HELP- 12v Light soure. Pod. Gauge.
Old May 22, 2009 | 11:48 AM
SilverDog's Avatar
Exclamation HELP- 12v Light soure. Pod. Gauge.
I'm trying to wire up my gauges and I'm not sure where to find a 12v Light source. I'm trying not to splice into any of my wires so I bought one of those "Add-a-line"(by buss fusses), which takes power from your fuss block. I have found a 12 ignition switch and a 12 light switch that comes on with the head lights but I can't find a 12v source that varies with the dash lighting. Not sure if you guys know if there is a 10amp fuss that I could plug into that varies. If I have to I can splice into a line.
I have one more question. When you guys added a full gauge pod did you have to cut up or put holes into the factory pillar in order to run you lines.
Old May 22, 2009 | 10:35 PM
SilverDog's Avatar
Any One
Old May 23, 2009 | 01:05 PM
02BlueStepside's Avatar
I cut my pillar for the gauge wires. And for the light source, I tapped into the dimmer switch. There is a thread bout it somewhere on here that shows the exact wire, I can't remember as its been a while.
Old May 24, 2009 | 09:14 PM
budhayes3's Avatar
PT's Slowest Truck
Yea, you're going to have to tap into the dimmer switch to get a varying voltage source that dims with the interior lights. It's really not that big of a deal if done properly.
RustyD
May 23, 2016 07:04 PM
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 28, 2015 08:24 AM
carid
Oct 1, 2015 09:22 AM
Lthompson
Sep 21, 2015 07:06 PM
