Heater sticks on hot side.
Old Apr 22, 2009 | 01:06 AM
7firebird1's Avatar
Default Heater sticks on hot side.
Hey all, I have a 2000 Chevy Silverado with a 4.8L. I have a problem with the heater sticky/staying on the hot side. When I start the truck up and it's on the cold side it is fine; but when I move it ever so little towards the hot side it goes hot and stays that way until I shut the truck off for 10 minutes or so. Any advice guys? Thank's in advance.
Old Apr 22, 2009 | 09:25 AM
This is obviously becoming a more widely experianced problem. Maybe we should have a Sticky Thread about this. Usually the problem lies within the HVAC Actuators. They control the movement of the Blend Door, Temp Door, Mode Door and the Air Inlet Doors attached to the heater box which is under/inside the Dash Panel on the passenger side. Sometimes an AC Control Head will *** out and cause these symptoms to arise but it's 90% of the time the Actuators. There si no easy diagnosis for this as you have to test the workings of the actuator in question and see if it's actually actuating allthe way open of closed. Sometimes a simple Re-Park procedure can be done and fis the problem, but I do sell quite alot of these Actuators.
Old Apr 22, 2009 | 05:20 PM
7firebird1's Avatar
Thank's. That will give me a good starting point. How much do these actuators run if mine is bad? Are they hard to replace? Thank's for the help!
cheyenne383
Nov 13, 2015 09:24 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
Wrecker 426
Sep 30, 2015 09:39 PM
g6t6o
Sep 26, 2015 10:57 AM
BlackGMC
Sep 9, 2015 01:43 PM
