Having a problem with my DD
Old May 11, 2012 | 07:57 AM
12sec.5.3's Avatar
Default Having a problem with my DD
Yesterday while leaving work I noticed a huge cloud of smoke behind me. I thought maybe I was seeing things so I watched closely as I started my tahoe this morning and sure enough it looked like a damn mosquito sprayer. Blue-white smoke pouring out of the exhaust, but stops after a minute or so and it's fine after. Evidently it's an internal oil leak or something. If you know what this is please enlighten me. It's a 2009 Tahoe w/5.3 and 86,000 miles.
Old May 11, 2012 | 08:09 AM
swift700's Avatar
Bad valve stem seal or broken valve guide would be my first guess. Definitely sounds like a head problem. Pull the plugs and find the black, oily one. That is your problem cylinder.
Old May 11, 2012 | 08:19 AM
BigKID's Avatar
PCV issue?? Look thru the throttle body and see if the intake is full of oil. Other than that, if it only smokes after it has sat for a while, I agree with Swift's prognosis of bad valve stem seal(s).
Old May 11, 2012 | 09:59 AM
SnakeOiler's Avatar
Valve stem seals. Although you may also have problems with the valve guides as well.
Old May 11, 2012 | 06:06 PM
12sec.5.3's Avatar
Noticed while driving that my oil pressure is really low, like under 40. Constantly fluctuating between 20 and 40.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
