Has anyone had this problem
Old Nov 1, 2010 | 10:24 PM
06SilverBirch's Avatar
formerly 98wytebord (3-14-2012)
Default Has anyone had this problem
It's a 06 GMC Sierra cc and the other day my ABS and E-brake lights came on at the same time. Now everywhere I go they come on for a few seconds then back off. They are not affecting anything besides it's damn annoying. Has anyone have this problem before. Any help please thanks
Old Nov 1, 2010 | 11:00 PM
KleenHall's Avatar
the brake comes on to warn of an issue which is abs related, is your truck lifted? or modded with gears or anything?
Old Nov 1, 2010 | 11:02 PM
Bigredmariner's Avatar
I just had the same issue, I thought it was because of my gear change but when I jacked up the truck to do the front diff I found that I had a left front hub going bad. I replaced the hub but haven't finished with the front diff gear change yet but if I were you I would at least jack up the truck and check the wheel bearings and see if they are sloppy.
Old Nov 1, 2010 | 11:11 PM
The truck is not lifted or modded. It does pull to the right as it needs an alignment. The other day I ran my power wire for my amp through the boot for the e-brake cable underneath carpet. Thats when It started doing it that day. I don't believe that affected it though. Maybe its just a bad hub. Thanks for the quick replies.
Old Nov 2, 2010 | 02:11 AM
99LsSilverado's Avatar
check the ground cables on the frame under the drivers door to make sure that they have good connection
Old Nov 2, 2010 | 11:50 AM
toyota_scion_tc's Avatar
Registered User
Check your brake fluid and try bleeding your brakes.
Old Nov 2, 2010 | 06:47 PM
Thanks for the suggestions guys I will check it out. I haven't checked my fluid in a while but my pedal feels softer as in I have to push it in further now.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
