guys with 2-4 drop on nbs
Old Dec 31, 2010 | 01:58 PM
gavin05's Avatar
Default guys with 2-4 drop on nbs
i just installed a 2-4 drop on my nbs rcsb.shackles and hangers in the rear and its riding on bump stops in rear.are you guys having to c-notch the frame with a 4 drop in rear?
Old Dec 31, 2010 | 02:12 PM
niner's Avatar
I have a Bell Tech 3-4 drop and have least a few inches of Clarence in the rear. I have bottom out maybe once or twice only , but I will still be adding a c-notch in the future.
Old Dec 31, 2010 | 02:19 PM
gavin05's Avatar
evertime i hit a bump in the road it bottoms out.when i installed the hangers and shackles i noticed that the prevous owner must have took a leaf spring out.i have the bed off right now at my friends body shop repainting the truck and i figured now would be the best time to c-notch it
Old Dec 31, 2010 | 02:42 PM
kalikid06's Avatar
I run a DJM 2/4 drop and I had to C-notch the rear. I think it makes a world of difference. If your bed is already off, go ahead and do it
Old Dec 31, 2010 | 05:39 PM
.James.'s Avatar
what are you waiting on then, notch it to prevent bottoming out, and you will eventually go lower anyways.
Old Jan 18, 2011 | 10:35 PM
gavin2005's Avatar
Originally Posted by 1sik02
[/B]
your prolly right.when i get the tires and and wheels i want it might go lower.i did c-notched the frame but the stock shocks was bottoming out was alot of the problem.i also found that the owner of the truck before me took the middle leaf spring out so it was really droped 6 inches in the rear.i put them back in there and it lifted it up about 2 inches. it rides alot better now and sits level.
Old Jan 18, 2011 | 11:21 PM
kazfan30's Avatar
Most 2/4 drops on rcsb only bottom out on pretty hard bumps, unless like stated that a spring was removed... I may have bottomed out only a few times
Old Jan 19, 2011 | 12:14 AM
gs7793's Avatar
i daily drive my truck with a 6inch drop in the back with no c-notch and my bump stops practically cut off lmao, it hits on just about every little bump.... go ahead and notch it, i started out with a 4" drop in the rear too and just kept going lower from there and after you get done with the drop and start spending your money on go fast parts you run out of suspension money till you figure out how important it is for traction
Old Jan 19, 2011 | 03:22 AM
BadAssChevy327's Avatar
did you take the little bracket between the frame and bumpstop out? take that out if not and screw the bumpstop directly into the frame. theres a hole for it. then cut all the bumpstop off but the last pad of it. thats been getting me by for months. i ordered my belltech c notch from stylintrucks 2 months ago and its still on backorder.
Old Mar 20, 2020 | 12:51 PM
Jesus Lugo's Avatar
Registered User
Default I have an 03 Silverado single cab short bed
hey if I do 3/4.5 drop will I bottom out will I need a c notch because the last thing I want to do it cut my frame up?
