got some issues
Old Feb 14, 2009 | 06:14 PM
dkota1968's Avatar
Default got some issues
Well i got a few issues i need to address, getting warmer out so i can do it. First is I have a crackling noise around 75mph that sounds like its off the windshield. My old truck didnt have it and it is an aftermarket windshield, any thoughts, its annoying as hell.
Next is noise i have behind the dash, i heard there is a A/C coolant line recall or something that can cure this. Its almost like a bubbling noise and i remember hearing about it on here somewhere but couldnt find it.
Also the damn cruise control crapped out this week, i hit the button and nothing happens, tried everything and cant get it to work. Anybody have this issue? If so what did you end up doing? I has ETC to.
Last thing that started happening is a clunk in the front end when turing at low speed, only one clunk. I figured tie rods, ball joint or something like that. Any thoughts or ideas on these subjects would be greatly appreciated. I feel like its falling apart and getting fed up with issues, but still like the truck. Oh yea its a 4x4 also. thanks
Old Feb 14, 2009 | 06:31 PM
bigbadwolf54's Avatar
13 Second Truck Club
This sounds like your windshield reveal moldings are loose, the moldings on the outside of the windshield that run up and down at the a pillar, you can lift the lip up and put some black rtv under them and let dry then trim the excess away or you can buy the new "updated" moldings from GM
if this is a whoosh or gurgling type of noise at low engine speeds or after turned off then the bulletin might apply, there is a new designed hose available but honestly this has no effect on system performance and is only a PIA as you noted
this would be best checked out locally, could be anything from the switch to a bad ground
this could be numerous things as you noted
maybe that will point you in the right direction
Old Feb 15, 2009 | 01:34 PM
budhayes3's Avatar
PT's Slowest Truck
The clunk that you're hearing may be the infamous steering intermediate shaft clunk, all of our trucks do it lol. There used to be a grease kit available, but I think it's been discontinued as the shaft has been re-designed for the umpteenth time.
Old Feb 17, 2009 | 09:44 PM
dkota1968's Avatar
sry im just getting back to you guys, ive been f'n with my atv and it hates me at the moment. Those window moldings that are mentioned do you know if that would be a glass company thing or something i can do my self. The clunck thing amazingly isnt the steering shaft i know all about that one . Its a big pop but only happens one time when i turn.
Old Feb 19, 2009 | 10:58 AM
You can do the moldings yourself, or have a glass company do it if your not comfortable, but it really isn't that complicated if you take your time. I will get some pics up, if you'd like to show you what I'm talking about.
Old Feb 19, 2009 | 11:04 AM
BIRCHZ71's Avatar
the clunk may be your hub on either side....i had to have mine replaced...it was doing the same thing. fixed the problem
Old Feb 19, 2009 | 07:00 PM
Fireman31's Avatar
Make sure the cracking noise isn't something as simple as the type of wiper blades that are on your truck. My factory GM wipers used to make a rattling/crackling noise over 60mph. I switched to Bosch Icon contouring wipers, and the noise went away..........
Old Feb 19, 2009 | 09:21 PM
dkota1968's Avatar
bigbadwolf if you could post the pics that would be great. Looks like im gona have to just get my truck into the garage and check out the clunk saturday, should be warm enough. I'll def check out those hubs, on the last truck i heard the grinding noise not a clunk but will look anyways. Funny thing about the wiper blades is i just bought some rain X wipers last night because the gm ones finally had it. I ll get on the highway to check if the noise went away. Thanks for the responses guys.
Old Feb 21, 2009 | 04:00 PM
there's a pic to show which weatherstrip is likely causing this, to make sure you can try to run your finger under the lip of the strip on the windshield side, if its fairly loose you may have found your problem. The new designed strips from GM are more rigid and resist flapping in the wind, also bug shields tend to aggravate the windflow across the windshield and cause the strips to flutter.
To repair a loose strip you can lift up the lip and apply a bead of black RTV sealant under the lip to adhere the seal to the windshield. It may be needed to clean the dirt from under the seal first.
Old Feb 23, 2009 | 10:30 PM
dkota1968's Avatar
Thanks for the pic bud, ill check it out tomorrow.
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
dselby25
Sep 11, 2015 05:03 AM
Boyes50
Sep 8, 2015 12:06 PM
