Gm Part #anyone?
#891
Originally Posted by GMracer
SS? whats the difference, if your talkin bout the fiberglass streetscene one I got one Im not going to use.
btw all the wiper cowls are the same tahoe, escalade, yukons, silverados, sierras we all have the same windsheild.
#892
Originally Posted by 2004Denali
This is for the chrome pieces?
FRONT LH 15850545
FRONT RH 15850546
REAR LH 15850541
REAR RH 15850542
Thanks
FRONT LH 15850545
FRONT RH 15850546
REAR LH 15850541
REAR RH 15850542
Thanks
YEAH MARK..... TAHT CHROME STRIP COMES AS PART OF THE ENTIRE WINDOW SURROUND
#893
Originally Posted by truckmann
Hey can I get a part number for the rubber exhaust hangers? The metal inside of one of mine is almost all rusted away.
SORRY ABOUT THE HIATUS.... BEEN TRAINING FOR SERVICE ADVISOR POSITION...
TRUCKMAN.... WHICH ONE DID YOU NEED FRONT, RESONATOR?? MUFFLER??
THERES A FEW OF EM
15740773 EXH MUFFLER INL PIPE CENTER UPR
15152622 EXH MUFFLER INL PIPE FRT UPR
88936385 EXH MUFFLER HANGER
#894
Originally Posted by spitfire2332
This isnt for a truck and the G6 forums suck *** so here goes...
Need the part numbers for the 'pontiac', 'G6' and 'GTP' badges that go on the trunk of a G6 GTP. And the part number for those little GM badges they started putting on all cars.
15290127 CHROME PLATED "PONTIAC G6"
15290130 CHROME PLATED "GTP"
15223484 SMALL GM PLAQUE AKA "MARK OF EXCELLENCE"
#895
THERES A FEW OF EM
THERES A FEW OF EM
#896
I just need the very rear rubber part that the pipe hangs from before it turns to exit behind the rear wheel. I tried useing a cheap aftermarket one but it was about a 1/2" too long and consequently doesn't really support the pipe.
OK COOL SHOULD BE 15740212
#899
-lower front bumber valance
15034723
-left and right fog lights with mounting brakets and hardware
5977934 DISCARD BRACKETS THAT COME WITH FOGLAMPS
-pitman arm
26041014
-idler arm
26041013
-center link
12386615
-inner and outer tie rods
IN: 26054934 OUT: 26054936
-driver side motor mount...the rubber part
15149543
-driver side door switch for interior lights...mounted on side of dash board
15726710
-power steering pump
88985333
-reverse light switch
88996477
15034723
-pitman arm
26041014
-idler arm
26041013
-center link
12386615
15149543
15726710
88985333
88996477
thanks man...o on those foglights..is that part number for both of them or do i need 2 of that same number?
