Gm Part #anyone?
Old Dec 19, 2007 | 02:18 PM
  #1611
cmatt's Avatar
Looking for a couple of things:
1. Cap that goes with radiator overflow tank on a 2003 Envoy XL 6.2L.
VIN 1GKES16S536184890
2. Escalade headlight control switch from 2003 and up.
3. Smooth paintable mirror caps for GMC Sierra Classic.
4. Is the serpentine belt (12576451) that fits a 5.3L with 145A alternator the same for a 160A alternator?
5. Tailgate cap that goes with this VIN 2GTEK13Z971111600.
6. Paintable side molding for a crew cab GMC Sierra Classic.
7. Step shield for Sierra Classic crew cab. Like this for ext. cab (12497356), but for crew cab.
I know it's a lot. Thanks for the help.
Old Dec 19, 2007 | 03:52 PM
  #1612
CHEVRACER83's Avatar
Originally Posted by hirdlej
I need the part # for a pilot bearing for a 4.8L 5 speed manual trans combo. Here's my vin if it helps: 1GCEC14V04Z314029
12557583
Old Dec 19, 2007 | 05:34 PM
  #1613
TEXASMADECHEVY's Avatar
sorry i dont have the vin but i need the part # for a pinion seal off a 410 diff for a 2003 silverado ss...thanks in advance
Old Dec 20, 2007 | 05:30 PM
  #1614
26064029
Old Dec 21, 2007 | 12:27 AM
  #1615
blksilverado's Avatar
I am looking for the part # for stock ls1 5.7 pistons. I have 12575663, but its not giving me anything. Did they change the part #?
Old Dec 24, 2007 | 10:53 AM
  #1616
67Cowboy's Avatar
Question Converting to pulse or intermitant wipers
Guys I have a 1976 C30 that I would like to convert to intermitant/pulse type windshield wipers. I believe I need the switch that fits '78-'83 but I don't know if I need to change wire harness or wiper motor. Do you have a listing for the numbers and their differences ?!?
Old Dec 25, 2007 | 10:46 PM
  #1617
cmatt's Avatar
Any luck??
Old Dec 26, 2007 | 04:17 AM
  #1618
xXxSilveradoxXx's Avatar
I'm looking for the part number for a couple of crossmembers on the chassis. I'm not sure if you can order these from the factory or not but I need some none the less. I'm looking for the two crossmembers that are behind the rear axel that hold the gas tank. The vehical is a two door Tahoe. This is what they look like. (these specific crossmembers are on a OBS Suburban, the 2-Door Tahoes that I need may appear different)
The crossmember closest to the axel.
The crossmember closest to the rear bumper.
Also, this should be easier, I need the hollow stud that the oil filter screws onto on a 1998 C-2500 with a Vortec 454. You can see it missing in this picture.
Old Dec 26, 2007 | 03:22 PM
  #1619
Derek @ EDO's Avatar
FormerVendor
I really need the rubber mounting grommet for the 05+ Fans, can anyone get me this piece?
Old Dec 26, 2007 | 03:38 PM
  #1620
SORRY DEREK THEY ONLY COME ON THE SHROUD
