Gm Part #anyone?
Old Sep 25, 2007 | 05:27 PM
  #1401
stone150's Avatar
sorry to speak up again, turnsout i need a new part:
Fuel Pressure Regulator 01 5.3l
power mirror switch
neutral dash bezel
thanks again!
Old Sep 25, 2007 | 06:18 PM
  #1402
CHEVRACER83's Avatar
power mirror switch
neutral dash bezel
thanks again!
IM GONNA NEED YOUR VIN FOR THE MIRROR SWITCH.
THE REG IS 17113700
THE BEZEL 15085847
Old Sep 25, 2007 | 09:03 PM
  #1403
cmatt's Avatar
CR83,
The truck in the pic is actually mine, but my interior color and the one associated with that VIN is the same. Thanks for double checking.
I can't thank you enough for getting those part numbers for me. I'll PM you my fax number at the office.
Old Sep 26, 2007 | 10:18 AM
  #1404
hirdlej's Avatar
Default Need Part # for steering shaft bearing and adaptor assembly
Do you guys know what part or parts I need to replace this on my truck? It is called a bearing and adapter assembly. It is right there where the steering shaft actually bolts up. its right above the shaft.... Here's my VIN: 1GCEC14V04Z314029
Old Sep 26, 2007 | 10:29 AM
  #1405
97Redbirde's Avatar
Question
Trying to find out the part number for the black rubber mat that goes on the console?
Old Sep 26, 2007 | 10:47 AM
  #1406
the only one i can find is a steering column inner bearing... it goes right above where the intermediate steering shaft bolts up..
26001827
Old Sep 26, 2007 | 10:48 AM
  #1407
15168289
Old Sep 26, 2007 | 10:49 AM
  #1408
Originally Posted by cmatt
CR83,
fax will be sent in the next hour or 2... gotta print em all out
Old Sep 26, 2007 | 05:35 PM
  #1409
flossinon_24s's Avatar
Can you give me the part number for a 03-06 glove box assembly in pewter for a truck with a center console?
thanks
Old Sep 27, 2007 | 10:34 AM
  #1410
thanks
there are 2 pewters.. 15216092 standard pewter rpo code 92I
15807856 very dark pewter rpo code 69I
your putting a center console in your truck or you already have one??
