Gm Part #anyone?
Old Jul 10, 2007 | 04:44 PM
  #1161
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
How about a number for a passenger-side power telescoping mirror with turn signal built in for '05 2500HD. Like the ones pictured here:
They have the rubber "accordian" boot on the extension part.
VIN# 1GCJK33205F878268 will probably work.
Old Jul 12, 2007 | 04:08 PM
  #1162
CHEVRACER83's Avatar
Originally Posted by 1SlowHoe
Looking for the P/N for the transmission line connection that screws into the 4L80E case. The one closest to the tailshaft if it matters. Mine was damaged and the line lock wont snap in place. Its a 2005 trans.
15812029
SORRY FOR THE DELAY... WORKS BEEN REALLY BUSY
Old Jul 12, 2007 | 04:14 PM
  #1163
Originally Posted by GMracer
any difference between 4wd and 2wd 99-06 spindles? part numbers?
THE KNUCKLE IS THE SAME... ITS THE HUBS/BEARING ASSEMBLIES THAT ARE DIFFERENT
Old Jul 12, 2007 | 04:21 PM
  #1164
THE ONES OFF THAT VIN ARE
15182964 LH
15182965 RH
BUT I DONT SEE THEM LISTING T/SIG..
Old Jul 12, 2007 | 04:51 PM
  #1165
i have diff hubs just makin sure i can use my stock 2wd spindles on the 4wd truck thank you
Old Jul 16, 2007 | 12:59 PM
  #1166
VTODD's Avatar
i would appreciate the part numbers for the door-side molding off of the NNBS 2007 silverado LT's. black to be specific, unless its paintable only. i wish i could provide more details, but thats the only way i can describe it. my LS NNBS didnt come with them, but today i saw a LT NNBS silverado with the side-panel thingys on the doors.
thanks!
todd
Old Jul 16, 2007 | 03:15 PM
  #1167
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
2000 Trans Am
I need part numbers for the following:
1) Engine wiring harness
2) The rubber/plastic pcv hose that surrounds the intake
3) Both fuel injector wiring harnesses (if separate from the engine wiring harness)
4) The black plastic airbox base
5) The plastic that runs around the base of the windshield
Thanks,
Scott
Old Jul 17, 2007 | 07:55 AM
  #1168
nighthawk08's Avatar
floor carpeting
1GCEC14C07Z616830
Old Jul 18, 2007 | 11:32 AM
  #1169
99 silverado fuel sending unit? thanks
Old Jul 18, 2007 | 12:45 PM
  #1170
got it.. nevermind
