Gen 3 to Gen 4 Silverado swap
Old May 20, 2023 | 07:50 PM
  #61
shakenfake's Avatar
Shlumpt
5 Year Member
Right. You have to choose what FEAD you want/how you want to space everything out. This is why truck intake is better
Old May 20, 2023 | 07:52 PM
  #62
robbieroflcopter's Avatar
So no way to adapt it? Or a different throttle body?
Old May 20, 2023 | 08:18 PM
  #63
https://www.holley.com/products/engi...s/parts/717-15
This maybe?
Old May 20, 2023 | 08:49 PM
  #64
RDF1's Avatar
DuNnO
5 Year Member
Maybe it was a LC9 water pump then.
Old May 27, 2023 | 05:39 PM
  #65
Default Engine is in!
Question at the end.
I got the engine, tranny and transfer case in. Driveshafts and starter also. Driver's side accessory drive and throttle body done. For posterity's sake, here's what didn't work: bellhousing is a different bolt pattern. DBC throttle body will not fit with the truck water pump. I used the ict rotation adapter and the lt4 angle adapter to make it work. That holley DBC plate did not fit my cables so I modified it. Otherwise most everything worked. The ls3 oil pressure sensor will not connect to my harness. I have an oil pressure sender in the old lm7? Single wire. Do I need to swap the sensor to get my Guage to work?
Old May 27, 2023 | 06:18 PM
  #66
shakenfake's Avatar
Shlumpt
5 Year Member
yesss
Old May 27, 2023 | 06:24 PM
  #67
Is there any way to adapt the sensor to my one wire plug and have it run my Gauge?
Old May 27, 2023 | 06:25 PM
  #68
shakenfake's Avatar
Shlumpt
5 Year Member
Just swap the sensor. Why is this even a question?
Old May 27, 2023 | 06:27 PM
  #69
Just curious how it works. And the engine is in so not a lot of room to get at the sensor.
Old May 27, 2023 | 06:29 PM
  #70
shakenfake's Avatar
Shlumpt
5 Year Member
Sensor is somewhat tricky but not too bad to remove. You need a special socket from Lisle. I have it and will look for P/N for you. I have removed it a few times now.
Answer is no to previous question.
