fuel regolator 5.3 !!!
Old Dec 4, 2011 | 06:48 PM
corvette_uae1's Avatar
Default fuel regolator 5.3 !!!
hi guys i want to change my stock fuel regolator
i already buyed sx fuel regolator
i heard that stock regolator in silverado 2008 5.3 is in tank!!!! so how can i change it
Old Dec 5, 2011 | 09:53 PM
ayousef's Avatar
you have to block the intank regulator if you still want to use the stock fuel pump, but let me ask why do you want to switch to a return style?
Old Dec 6, 2011 | 03:24 AM
i just add a turbo but the fuel regulator and fuel pump is next then ill move to the injectors
Old Dec 6, 2011 | 05:12 PM
ayousef's Avatar
what year truck is this, because if its one of the new trucks then you have a fuel pump control module which I dont know how to get around either.
How much power do you want to make, if its a newer model truck you can use a boost a pump until it maxes out, also do the injectors before the fuel pump because you will max the stock injectors BEFORE you max the pump.
Old Dec 6, 2011 | 08:40 PM
2008 model and my goal is 500rwhp max
im changing the injectors but what i know is fuel pump and fuel regulator should be changed to
Old Dec 6, 2011 | 08:52 PM
Atomic's Avatar
I have a gauge for that
return the REGULATOR you bought and put an aeromotive 340 in your tank
Old Dec 11, 2011 | 07:17 PM
thanks atomic helped me alot
yeah im curious about the walbro fuel pump more than 20 of my friends had a failure fuel pump some stops after few days and some will wont survive for a day ! i mean before no one had issue with walbro are their replica walbro from china?
5.3Okasai
Mar 9, 2022 01:07 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Sexyrado327
Aug 2, 2015 04:08 PM
MS3Z
Jul 30, 2015 06:17 PM
04450r
Jul 24, 2015 01:58 AM
