Fuel mileage fix
#32
He charges for that, my local dealership said it would be 85$ to do a full diagnostics to see why I get such poor fuel mileage whether it be a pcm update or out of range sensor, seem worth it?
#33
you would be paying $85 for them to overwrite the tune thats on it, then you would have to get it retuned for things like the fans. Seems like a waste imo.
How much does your tuner charge? $100 for a retune? I think that'd be worth it
#34
#36
I agree that you should get it retuned, on a dyno preferably. My 2001 runs great and I don`t drive it like the old man I am, I could get better mpg but I don`t like driving like a old fart in a Prius. I get 12 mpg in city 15 highway, I think 10 is a little low.
#38
#39
I've checked and hubs are unlocked while driving, idk what the previous owner could have done becausecive replaced mostly everything from plugs, fuel filter, air and oil filter, fresh fluid all the way around, no dragging brakes, new o2 sensors, only things I have not changed are injectors really, idk what else to check, faulty tps? Iac? Who knows, but 10mpg for when it was bone stock, and 9mpg after a full tune up with a tune just isnt normal, if you get what I'm sayin, I think it should just get more mileage as it is rather than me needing to dump several hundred dollars into upgrades
#40
because the tune is exactly what controls how much fuel the engine uses.........
The tune controls when/if the TCC locks up..........
The tune controls where the trans shifts.............
The tune controls the speedo that may or may not be accurate thus throwing off the numbers this guy is calculating.........
Because the tune is more likely to be "less than optimized" vs "a wrong part" installed by the PO or even the OP
Also, since 1988 in the pickups and 1992 in the Suburbans; there are no front locking hubs. Everything up front spins on a 4x4 when disengaged. A wheel hub thats dragging enough to eat MPG is going to be A) noisy B) hot
