FUEL ECONOMY..... 5.3L vs. 6.0L in a 1/2ton
Old Nov 21, 2010 | 03:24 AM
  #41
fastnblu's Avatar
Originally Posted by Atomic
I got better mileage with my 408 and tvs1900 than I do now with a stock 5.3
With the 408 I got roughly 9-11 around town, and 14-15 on the highway, the 5.3 gets 1mpg worse and less than half the power
Im sure I could get 2mpg back if I had normal size tires, ...
Think it'd be that much different if u had a 6L / 370? How much weight how u pushing in that beast? I know you're way more than my lil RC.
Originally Posted by GMCtrk
Yep, I get 6-8 city and 12-15 highway. ...
That's horrendous.
Not sure who does your tuning, but u might wanna get someone else to do it. A lot of guys like Blackbear & Wheatley.
Old Nov 21, 2010 | 03:37 AM
  #42
Atomic's Avatar
I have a gauge for that
Mine weighs 6400lbs with me in it and a full tank of gas...
Old Nov 21, 2010 | 07:59 AM
  #43
Best mileage I could get in my 2wd crew 5.3 is 18 Highway and it even has the shitty 3.23 gears. Why 3.23's GM? WHY? City driving is always 16. My rcsb with the lq9-t56 will easily get 15mpg city, never checked it on a road trip.
Old Nov 21, 2010 | 01:09 PM
  #44
GMCtrk's Avatar
Originally Posted by fastnblu
That's horrendous.
My fueling is dead on, wideband verified. Thanks for the advice though. Put a cam and 3600 stall in a 2500 HD and let me know what gas mileage they get. They barely get 11 mpg stock, although they are weighing about 1k more.
Old Nov 22, 2010 | 08:15 AM
  #45
slpsilverado's Avatar
Originally Posted by slpsilverado
My wife's Honda Accord doesn't even get 32 MPG!
You need to manually check your numbers. (Miles driven / Gallons needed to fill up = Approximate MPG)
I usually get 400 miles with 22 gallons of gas. 400 miles / 22 gallons = 18.18mpg
22 gallons? I thought that mine (RCSB) was 26, and an extra cab was 29?
I never said I had a 22-gallon tank...I have a 26 gallon tank; I just choose to fill it up one tick mark before "E". As long as you are consistent with your fill-up point, you do not have to run it dry to get accurate manual MPG calculations. You won't see this guy sitting on the side of road out of gas. A friend of mine who works as a mechanic at the local GM dealer told me that running the tank almost completely dry is hard on the fuel pumps, too.
Old Nov 24, 2010 | 11:07 AM
  #46
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
Originally Posted by denali_on_26's
driving how i wanna .... 13.8mpg
going on tomorrow:
long tubes, ORY, 3" to magnaflow, and K&N hoping for a little extra
remember this is all with 24x10 wheels
interstate driving 70-75mph i am getting 18.7mpg
highway 55-65mph i am getting around 17.6mpg
average now being 16.8mpg
it was 13.8mpg
Old Nov 24, 2010 | 07:35 PM
  #47
fastnblu's Avatar
Gotcha. If I owned a 2500HD, I would be a dipshit to put a 3600 stall & cam in. I'd buy that vehicle as a workhorse & a lighter truck as my bullet.
I never said I had a 22-gallon tank...I have a 26 gallon tank; I just choose to fill it up one tick mark before "E". As long as you are consistent with your fill-up point, you do not have to run it dry to get accurate manual MPG calculations. ...A friend of mine who works as a mechanic at the local GM dealer told me that running the tank almost completely dry is hard on the fuel pumps, too.
It's not a bad idea to stay under the fill mark & not overfill, cause it can to lead problems from what I've heard on here. You're correct, it's also a bad idea to run til near empty, it's hard on fuel pump, since being submerged cools it.
Currently, my MPG is terrible. Maybe it's due to my stall, cam, I now it's cold here; needs a re-tune I'd think. I have an Evap /Fuel issue, & haven't checked my codes recently. It's gotta be in the 10-13 city range.
Old Nov 24, 2010 | 11:22 PM
  #48
do ya'll think the 3.42 gears are hurting or helping the fuel mileage?
i have a set of 3.73's i could get installed if it would help out...
i'm just wondering because of it being a crew cab and with 24x10 wheels and 32.5" tires if the 3.42's are makin the truck lug alittle... i am at around 1800ish@70mph and 1850ish@75mph
help me out with some thoughts
Old Nov 24, 2010 | 11:50 PM
  #49
Atomic's Avatar
Well I can tell you my experience going from 3.73s and 35s to 4.56s and 35s.....with the 3.73s, my gas mileage had a bigger range, it would b e something like at worst 8 and at best 18. with the 4.56s it had a smaller range but the average was about the same, it would be something 10 to 16. In both cases the average is 13, but the local values are different.
Old Nov 25, 2010 | 10:39 AM
  #50
hmmm...
anyone else have more thought?
