fog lights
depending on if you want to use your own wiring,relay, and switch..
you can either use your stock bumper and cut the holes youself
it can be as cheap as around $100
but you can buy the kit which is part number 12499673
Contents: Fog/cargo light switch to replace cargo light switch in dash.
2 Fog Lights
Harness
Relay
4 bolts, four clip nuts
Cable clips
Instruction sheet in English and French
Air dam with push pin fasteners
personally, i am going with doing it myself, but the kit is $253 shipped from gmpd
2 Fog Lights
Harness
Relay
Cable clips
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 1, 2015 09:22 AM
