fog lights
hey guys... im new to the forum...not sure if any one can help me out.. im lookin to throw 6 fog lights on my roof rack... how do u wire them together?<wireing diagram would be helpful> so its all off one switch...do i have to worry about my battery/altanator? n e help would be great
Thx Smokey
Thx Smokey
you might have to drill into your roof in order to run wires, unless you can use existing holes from the roof rack. from your battery i would run 12 gauge wire to a relay switch, then straight to the lights. no need for a wiring diagram because you will be running your own wire. then find a good ground. sounds like they will be drawing alot of power. i believe your altenator and battery should be fine. i run after market PIAA fogs, 1000 w amp, and other stuff. just recently i upgraded to a optima yellow top, but my stock battery worked fine.
Originally Posted by SmokenFasTT
so ur tellin me run the 6 fog lights to a bus strip than from the strip to a switch..no need for a relay each pair comes wit a relay do i need to use it?
each set comes with a relay im buying 3 sets so i have to use all 3 relays? trying not to sound like moron here lol... i kno how to hook up fog lights i have done it before just dont want summthin to short and start a fire want to only use 1 switch and 1 pwr wire...so if i use the 3 relays.. i will run 1 pwr wire to a bus strip than the 3 relays to the bus strip... so i guess that the best way to do it?
dantheman1540
Feb 24, 2016 09:56 PM
carid
Oct 1, 2015 09:22 AM
