F350 tears a new one.....
Originally Posted by bludool
Found out a little more info on the truck. It is a FORD, however it is not running a Powerstroke, it is a 12v Cummins.
Originally Posted by 1BADHD
Its possible. I seen in OFFROAD a few months ago. The yanked the Strokeand stuffed in a Cummins.
Any ideas why the Navistar Powerstroke was tossed? Can't you get insane amounts of power from those?
Originally Posted by Hit Man X
Crazy! I never would have guessed that would be do-able.
My truck weighs in at 6300 with the lift. So given its a 1 ton....I used 7500# for the weight. I used this simple calculator.http://www.dsm.org/tools/calchp.htm With the given time and speed. Its pushing around 950 HP!!!
The powerstroke as a motor is starting to develop some serious H.P. +500 and over a 1000 pounds of torque, however it cost quite a bit to get it there, new injectors--$4,000, New Turbo, $3,000, New Trans--$4,000, Fuel system reworked--$2,000, New Chip, $500, it all is pretty expensive, however the Cummins has some very "user" Friendly components, injectors are way less money, maybe a quarter, new turbos or even twins can be used, there may only be one or two twin powerstrokes in the country, way more difficult to put twins on. There are guys with street driven cummins powered vehicles that are running close to a 1000 hp, with over 1500 foot lbs of torque. For grins, do the calculations of what it would take to push a 8,000 lb truck to an 11.42 in the quarter at 118 mph. Diesels can and do make some serious power. BTW, the Chevy's are really coming on as well. Hope this helps.
Good info!
On a side note, he runs twin turbos producing 95 lbs of boost!!!!! He has dynoed over 800 rwhp with #2 only (diesel), no drugs. He does have both propane, and nitrous available if he wants. His goal is to go 10's.
check out the link in the multimedia section, i copied his sig info in there
https://ls1tech.com/forums/showthread.php?t=116441
